It is currently Mon Aug 25, 2025 1:26 am
 Post subject: String nuts
PostPosted: Wed May 08, 2013 10:27 am
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Zip/Postal Code: 30308
What causes that "dead" sound? Let's just assume that nut action, bridge action, neck straightness, neck pitch & fret level are all sufficient. The sound happens only when the string is played open.
I get this from time to time and I end up just messing around with sandpaper, files, razor blades, etc. until it goes away but I'm not sure why it happens. It seems to only happen on the treble strings. Particularly the high "E".
"I'm not going to say that perfection has never been achieved. However, if it has, it probably went unnoticed due to it's lack of character."
 Post subject: Re: String nuts
PostPosted: Wed May 08, 2013 10:36 am
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Not proper relief in the nut slot? Could be more flat than necessary. Causing it to be muted. You need the string to "break" over the front of the nut.
PostPosted: Wed May 08, 2013 11:27 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Your nut slot is most likely lower at the front than at the back. The string floats through the slot and that deadens the vibrations.
Brian
PostPosted: Wed May 08, 2013 12:22 pm
First name: Zeke
Last Name: McKee
^^ that's what I was trying to say^^
Boy am I bad at forming thoughts into sentences.
PostPosted: Wed May 08, 2013 2:44 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
I generally do file flat to get the basic height and then angle the file at the approximate angle of the string. I will have to start checking to make sure it's not sitting on a hump in the middle of the slot.
Any other thoughts?
How about if it still sounds dead when fretted? This is again assuming adequate string clearance.
PostPosted: Wed May 08, 2013 2:47 pm
First name: Zeke
Last Name: McKee
Then I would assume it is the same issue, this time on the saddle rather than the nut.
PostPosted: Wed May 08, 2013 4:06 pm
Online
I always start with the cheapest thing on the instrument - that's strings.
We are talking a few cents worth of steel and brass.
Change the string, and then decide where to go next.
Do a once over of the whole instrument, then start at the peghead and work to the butt of the guitar.
PostPosted: Wed May 08, 2013 5:56 pm
First name: D
Last Name: S
+1 on Old strings
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu May 09, 2013 6:02 am
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
I'm working with new strings in most cases. This sort of thing is tough to figure out because its so microscopic.
PostPosted: Thu May 09, 2013 10:18 am
Online
New strings can sound like crap right outta the package.
PostPosted: Thu May 09, 2013 10:35 am
I never file at a flat (zero) angle. Always split the difference between flat and the headstock angle. This makes sure there is sufficient contact at the front edge of the nut.
